Decals on Oil Filter, Screen Wash Bottle and Air Cleaner - CHECK!
Air Cleaner in place - CHECK!
Visors, mirrors, side windows and door handles fitted off - CHECK!
Front emblem badge and License Plate decals on - CHECK!
Rear License Plate decal on - CHECK!
LHS Name decal on - CHECK!
RHS Name decal on - CHECK!
Well, after almost 4 years and a number of restarts, this one is DONE and on the display shelf!
My thoughts - overall an excellent kit. I would love to pick this one up again and have another go at it, knowing now what to watch out for and what needs more attention. In general the mouldings, details and fit were great. The stumbling block with the front grille was quite likely my own doing, just didn't quite line up the chassis/body assembly stage at the front end.
The windscreen glass/frame issue is definitely kit related. The glass doesn't fit the frame at the sides, there is a gap of almost 1mm between the clear part and the frame on each side. The clear part "overshoots" the frame on both sides by about 3-4mm and interferes with proper placement of the side windows. The side window frames and clear parts are almost 2mm oversized, they should sit on top of the upper door trim and inside the line of the windscreen frame. All of these issues could be rectified and I certainly would go about it if I had a chance to build this one again.
I'm not super happy with my paint job on this one, the old "orange peel" is present despite several sessions of sanding and application of MLT to smooth it down. We learn and improve with each kit we build, and I certainly picked up a few lessons here.
Thanks for joining me on this (lengthy) trip.
