Hi gents,
Thanks for having a look -
D, I'm sure you'd power right through one of these! it seems that one of the biggest factors in getting these done is positive mind set, followed closely by patience!
Hi Joel, again, I appreciate your optimism! I'm still not willing to speak the words, "yes, it will work fine" hahha thanks -
In the meantime, some pics of about half of what I'm doing so far.
This is the rear canopy - don't be fooled by the top two pics:
Famous last words, "sure looks good!" - - I'm not convinced at all just yet. First, it took a long time to get this to even sit flat. The tube chassis was a bit warped horizontally, at the top, meaning the wheels sit flat on the bottom, but the canopy on top, didn't. Let the terror begin - apply steady, gradually increasing force on the chassis in an effort to bend the top of the frame, while not destroying it. It worked.
Next, on the underside of the canopy - there are four key locating and connecting points:
As you can see, there are two pins in the rear, and two arms for hinges in the front. These are to be glued into subtle indentations in the resin canopy. This works fine, but having been around my own builds long enough, I am fully confident that these points would snap off during fitting, and then during use. So, I used scrap brass photoetch material to make retainers, as shown below:
Above, you can see a connection for the hinge arm - glued flush on the canopy, and curved to match the curve on either side of the arm, ideally holding it in place.
Next:
In the rear are these locating pins that lift in and out of the chassis receiving points - what could go wrong here?? I'd knock them off, that's what! so, more brass retainers. For these, I made little two prong forks, that wrap the base of the pin, covering a base that is wider than the pin itself.
Challenges for this bold move: Cut an opening in the retainer that is the right size....then, make a "Z" fold in the sheet brass, that steps off the base of the pin that lands flush to the resin canopy....CA prefers to work on flush surface to surface connections - cheating doesn't work, I've tried.
In the meantime, I painted up the rocker panels and some other parts - these are sitting in my laundry room, near the hot water heater right now - why you ask? It's raining here - and the acrylic finish wouldn't dry with all the humidity! lol - so, as I'm at work now, I'm hoping these will be baked/finished when I get home, so that I can apply my water based, acrylic clear coat! what could go wrong??
Cheers and happy model building -
