Hello gents,
And happy Saturday night! Have we got night planned! a couple bottles of a Cab/Syrah blend and a DVD of a Grateful Dead Show from 1987 - that I was at! woohoo - and, before, an update on the snappy P34.
Hi Gabriel, well, maybe you won't spend unnecessary time fiddling with parts that no one but us will see, but, and a big but, your body work will no doubt outshine my shenanigans with bits and pieces! Glad you like what you're seeing though -
Damian, thanks and glad you enjoy seeing this stuff - my blogs seem to be fairly quiet in terms of comments, so, I appreciate you putting up with my rambling and sometimes misguided efforts at adding more to these kits! As I've recently noted, now anyway, this guy has the excuse of a quarantine to be pursuing this stuff!
Ok, for tonight's set, only the rear tail. I've now worked with a lot of PE, on a variety of kits, but mostly 1/35 armor, and along the way, I've learned that yes, it's clearly possible to add this stuff and it's worth the effort; next, it's never as easy as the instructions suggest; and, along the way, I will destroy whatever it is I'm building at least twice before it's ready to show!
So, on with the show, a fine lattice/truss that looks really nice that supports two vertical struts and two wing planes - and, as always, how hard could it be?
well, take a look:
Above, you can see two big etch pieces forming the truss. The thing is, the instructions suggest a simple fold of one large piece, that you "just" glue into some precut slits in the vertical elements, then "just" fold and add the second big truss piece, by "simply" inserting it into a couple more precut slits.
In reality, I was unable to achieve this simple task - the "just" or "simply" parts of the instructions, or should I say, I predicted I couldn't, so I did the right thing and didn't follow the steps provided. Instead:
1) reamed out the slits a bit with the Xacto, so that the truss micro-tabs could actually be inserted into the slits;
2) insert and glue the "big" truss tabs into one side first, and then, reinforce the inside edge of the connecting edges with really small sheets of aluminum foil glued to both sides;
3) inset and glue the "small" truss per above;
4) then, install the "second" vertical element to the other side - a note here is that the instructions imply that you should add an additional piece of sheathing (big pieces of PE) to each of the verticals before you insert the truss elements - I didn't do this first, because, if you do chances are good that you will either: 1) get glue into the slits, or, making the receiving depth of the slits too shallow to receive the trusses. Ask me how I guessed this?...;
5) As the truss is relatively big, and made of etch...it's flimsy!! something I would no doubt bend or break, so, you'll see I added 1/16" wide, really thin brass bars to stiffen it up. Yes, they overlap a bit, but, I'd rather have that than this thing breaking or twisting whenever I handled it - I hate making fragile models; and,
6) the instructions would have you install some really small etch "benches" to support the "big: wing - nope - those will fail - so, I added doubled up pieces of brass bar instead - if you look toward the top of the part, you'll see them sicking out of the vertical elements.
and with the wing:
Unlike the delicate etch, the wing is big, clunky plastic - featuring lots of flash and irregular surface plane, which is nice. Strangely, the big wing rests on the aforementioned "benches" while the comparatively small upper wing, is installed with sturdy, giant plastic pins...yeah...no. So, the lower, bigger wing is mounted on my brass benches, and glued. For the upper wing though, I cut off the provided chunkster plastic pins, and replaced them with thin metal rods, capped with small etch washers - stronger and better looking than the solution provided.
And, despite this effort to create a light and tough assembly, I essentially disassembled/destroyed it twice - very gracefully I might add, by dropping it onto the ever-forgiving concrete floor below my work area! What a treat -
No matter the process, now that it's said and done, I think it looks pretty good
OK gent, we've got some wine to drink and Grateful Dead music to enjoy -
Stay well, and keep building
