With the basic body shell completed, I next turned my attention to the chassis and the front & rear suspension sub assemblies. I must say that I was rather impressed with the detail of the complex suspensions, as both really looked more then quite good and equal to many of today's kit offerings, especially considering that the kit dates back from 1992.
I started off with the usual cleaning up of all the parts as there's an abundance of seam lines everywhere. Unfortunately, my effort still left a few here and there. Once that job was done, I've started the paint prep with a 15 min bath in Polident & room temp tap water. The parts not only come out spanking clean, but have a rather nice fresh scent to them.
I'm still in the camp of priming every
thing no matter what, so I used the last of my Gunze #1500 gray primer thinned 1:1 with Gunze #400 Mr. Leveler Thinner. I let the parts dry and cure for a few hours then I air brushed on Tamiya Semi Gloss Black, with the upper A arms in Gloss Black, and the rubber boots on the steering rod that connects both front wheel assemblies Tamiya Rubber, which really looks like their plain dark military Gray is you ask me. The following day I masked the cover of the rear end which is part of the rear axle, and then primed it once again as I forgot to mask it off when I painted the axle the day before. Several coats of Tamiya Gloss Red was air brushed on as well as the main body of the rear end gear housing.
The shocks/springs already were air brushed Semi Gloss Black, but the springs should be gloss Black, so I hand painted them as well as the tops and bottoms of the shocks Mig Ammo Polished Steel.
And a quick test fit of the engine/transmission.
