Just got to clear some builds off the bench then I will start mine
Not to sure which car I will be doing but I have a week to think about it as I go back on night shift tonight so no modelling or internet
for five days.Ciao
Luciano
for five days.
). Again, a lot of what is seen now will not be seen once the Deora has her body parts put on (I won't be redoing the radiator cap [small round blob on the top] nor the valve cover's breather [though I may add the line from the other "doohicky" to the carb]; basically, if I figure it can be seen from below, I'll try to replicate it. Sans the plug wires, what you see is all the kit provides...very basic).
...I wised up and used solder. Amazing how much easier that was! The top hose is done and I need to determine the location of the bottom (the kit radiator is actually quite "long/tall") hose. The "framing" and top of the radiator will be painted to match the engine, the supports painted to match the frame, and the radiator core will get a flat-black coat.
) shot of the exhaust pipes...they've been double-beveled...front to back and top to bottom.
, shows the filter I attached to my spraybooth:
Oh winter in garage workshops![]()
I'll have half the garage for my wood shop. Right now I do all my modeling in the basement (spray booth vents out the back [previous owner idiot had someone cut a 4" diameter hole in the foundation so they could run less than an inch worth of electrical line for the hot tub]). Turns out that the "corner" of the basement my SWMBO has "allowed" me worked out well. In a few years, I'll finish the basement and put her laundry room on this side (and use the booth vent for the dryer) but haven't quite figured out where my modeling room will be, but it won't be in the garage, it'll be somewhere down in the basement.
And the silver base to show off the next layer is pretty wide spread. Lots of people swear by it.
had no idea...dude at the LHS said "use silver to 'bring out' this color." I'm learnin'. I know my brother, when he used to paint cars, would almost always use a base of white or black (depending) before the main color. Kool.
Some shiney spots, some satin spots and some "spits"... I have a feeling that this was due to not doing the right "mix" of paint and thinner and the paint may have been too cool. The paints are enamels, so I'm going to allow it to cure until at least Friday night before I attempt a "fix." I have some Acrylic clear gloss and flat...just need to decide which way to go. I actually like the idea of using the flat.
Doubt that'll happen though
I'm going to lightly sand the underside and steelwool it to smooth things out, reprime, and take my paints upstairs to warm up before reshooting the silver and the metallic black.
