Finally some pictures!!
First up the Bentley's interior has started to take shape.
The steering is in as are some more detail parts on the engine..
Then to the chromed pieces. I removed all the chrome using household bleach diluted with water. It did an excellent job and not a trace of the kit's chrome was left on the parts.
Then I applied the gloss black Alclad II Lacquer undercoat which came out amazingly shiny in itself. I wish Tamiya gloss acrylics would come out as shiny on my Lola!!
After letting it dry 24 hrs I misted on Alclad II Chrome ..
The parts need their final buff but it is much better than the original chrome finish.
The exhaust system is together..
Only the halves are glued together at the moment. It needs the join seams removed and some hgh-temp enamel.. Just kidding as I don't think the engine will ever run..
I have also assembled the bonnet pieces, which are workable,and have started with the rear seat area.
Next big problem is finding the right colour green for the body work and hopefully it will adhere to the kits plastic properly. The Humbrol acrylic I bought is hopeless for some reason. When yuou try and spray it on it just forms tiny droplets everywhere just like normal water would. Same as if you brush it directly on plastic it is like water and doesn't cover at all where Tamiya acrylics have no problem covering the same plastic. Won't be buying them again..
Cheers for now
Warren
