1951 Chev Bel Air - Charity Build
Posted: Thursday, February 14, 2019 - 01:52 AM UTC
Arrgh! That one starts resembling with one of my builds, when I get pinned into a point with the rest of the build just galloping forward (I still didn't finish my hood on Chrysler
). I think a little patience is the main ingredient there...
And yes, that red looks awesome!
Posted: Thursday, February 14, 2019 - 02:36 AM UTC
Sanding pen added to wishlist
Bummer about the fender skirt. Our hobby do bestow upon us a few setbacks once in a while, but we love it nevertheless
Great choice of red. Even with a little setback, you're making good progress.
Posted: Thursday, February 14, 2019 - 03:51 AM UTC
The Red really looked quite good. But having to go back and redo those skirts is a real killer. I have to tip my modeling hat to you, as you didn't hesitate one min, and just did what had to be done. I'm sure that the effort will be well worth the effort.
Posted: Thursday, February 14, 2019 - 02:08 PM UTC
Well for an early breakfast thismorning (before I headed out to work) I had a large coffee and a handful of wet&dry sandpaper
Primer tonight to see how this came up, then hopefully another crack at the top coat. I'm thinking a very fine rescribe of the fender/skirt delineation with a black pinwash after I'm happy with the top coat. I will cut a template of the shape before I prime it again.
European Union
KitMaker: 1,732 posts
Posted: Saturday, February 16, 2019 - 09:27 AM UTC
....Oh well, tear it off and back to the putty, sand, paint, . . . .
I've experienced about the same just a few days ago with my SAAF Gripen, Damian. Not putty and sanding but taking all paint off and do it all again. I know how frustatig it can be. Or as we say here in Germany "Nicht zur Strafe, nur zur Übung" which means in english something like "not to punish, just for practising" You'll get it .... That red on the engine hood looks awesome!
Torsten
My campaigns for 2020:
MiGs - Done !
The Big Three - Done !
65 years Bundeswehr - Done !
40 years Leopard 2 - Done !
Land Lease - Done !
Posted: Saturday, February 16, 2019 - 10:45 AM UTC
"Practise makes perfect" . . . plenty more practise required for me!
Thanks mate, that has had a wet polish on one side with a super fine sanding sponge. This is my first time using the locally manufactured SMS Lacquer paint on a large surface, so I'm trying out a few variations of airbrush setup and pressure, as well as sanding to get a nice polished finish.
I really appreciate the feedback, and I hope your next attempt on the Gripen works out better. It's such a cool looking airframe (as are all Saab models).
Posted: Saturday, February 16, 2019 - 02:04 PM UTC
Yaiks! Those skirts are haunting! I guess at this point the best solution will be to fill them completely with putty, sand flash and re-scribe the contours as panel lines. (It may be I'm not "reading" correctly the pictures - the darker plastic or putty had me confused).
Posted: Saturday, February 16, 2019 - 02:21 PM UTC
The slightly darker plastic is the remnants of my "sprue-goo" which is black. I have it sanded back nicely now and a fine coat of primer will show if I need to go over it again.
Posted: Sunday, February 17, 2019 - 04:38 AM UTC
I'm hoping that your repair does the trick. Looking forward to your pics.
Posted: Sunday, March 03, 2019 - 06:00 PM UTC
I have assembled the interior tub and firewall, installed the engine, and assembled the front inner guards and radiator. I still need to paint and detail the battery, give the engine a pin wash, and add a couple of parts to the firewall. Once the front assembly is complete the whole lot will get a bit of a pin wash, not to make it too grimy, just to pop the detail.
The lower body has paint and 3 light coats of SMS Super Clear Gloss lacquer. It will get a good wet sand then a further 2 solid coats of clear then a cut and polish.
After that I will mask for the chrome trims, then mask the trims up and unmask the roof for painting.
The side skirts came out quite good, I will get closer images of them once the clear is finished and I have scribed the join lines for pin wash. Overall this kit has been quite good. A bit fiddly in lining a couple of parts up where the joints were not defined, but once I worked it out it went together nicely.
Posted: Sunday, March 03, 2019 - 06:18 PM UTC
This is coming along really fine. Great to hear you were able to fix the side skirts.
Posted: Monday, March 04, 2019 - 04:41 AM UTC
Great progress for sure. Looking forward to seeing how your steps look as you go through the sanding, polishing, and waxing process, and then marvel at the perfect '51 Bel Air body.
Posted: Monday, March 04, 2019 - 01:43 PM UTC
D, the body looks good - no doubt. Now, seeing the interior / exterior together, I'm quite sure you have hit the jackpot with the color combo (saved for later in my database).
Skirts problem solved, you are clearly on the fast lane with this build and I am anticipating a very attractive finish.
P.S. What the "Magic" thing is on your desk? I guess it's a glue, but which kind / characteristics?
G.
Posted: Monday, March 04, 2019 - 02:38 PM UTC
Thanks Gabriel, I'm happier with the results on the body now.
G.
The bottle is "Plastic Magic" by Deluxe Materials, similar to Tamiya Extra Thin but with a lower odour, and I find on some of the older plastics it gives a stronger bond. It is suitable for use on a range of plastics as well, not just Styrene.
https://deluxematerials.co.uk/products/plastic-magic-1Quite a few local stores are starting to stock this brand now, and I use it more frequently on the older car kits.
KitMaker: 4,728 posts
Auto Modeler: 192 posts
Posted: Monday, March 04, 2019 - 07:38 PM UTC
This is looking nice D.
Two things, what are those two black things in the lower part of the photo?
The other is if I hadn’t of known that it was masked I love the effect of the paint on the roof, the photo makes it look sort of like a 3D custom mottled paint job.
On the bench...
Italeri A129 Mangusta
British Bulldog Spitfire theme build
Posted: Monday, March 04, 2019 - 08:08 PM UTC
Thanks Luciano. Now that you say it, the roof does look pretty cool!
The black things are shrouds that run either side of the engine from the firewall to beside the radiator. I will post up a reference pic soon.
#335
Auckland, New Zealand
KitMaker: 1,808 posts
Auto Modeler: 701 posts
Posted: Monday, March 04, 2019 - 09:44 PM UTC
Hi Damian,
I have just read this through from the start, I seemed to have missed it. Great idea and great cause, but what happened to the idea of keeping the colour a secret?
Campaign:
Strip, Track and Trail - Porsche 917/20 - On the bench
Phantoms at 60 - F-4J Marines
Below 1000 tons - M50 minesweeper - Sailed for duty
Posted: Monday, March 04, 2019 - 11:50 PM UTC
Hi Michael.
A few of us have been in contact on various Facebook pages and we decided that promoting the Single Kit Group Build by posting our progress would be more important in raising the profile and interest in the fundraiser, hopefully generate more entrants.
The judging will be a great fun event day regardless of how it turns out for any of us.
Posted: Tuesday, March 05, 2019 - 01:02 AM UTC
Luciano, here you go. You can see the black trunking or shrouds either side of the engine.
Posted: Tuesday, March 05, 2019 - 01:22 AM UTC
That moment when you scratch your head trying to work out what and where
The instructions are vague and there is no locating point on the firewall, and I have looked at as many engine bay shots as I can find for the 51 Bel Air 6-cylinder, these little things just don't exist.
Off to the spares bin with them!
Posted: Tuesday, March 05, 2019 - 03:18 AM UTC
Thanks D makes sense now, from the photo I was thinking the upper one was a very poor moulding of a diff, thankfully it’s not.
Ow parts that don’t belong, I think at some point most of us can share that head scratching moment.
On the bench...
Posted: Tuesday, March 05, 2019 - 03:49 AM UTC
D., isn't that two halves of a collar to lock the piece going thru the hole (air compressor?) from behind the firewall?
scratch! scratch!Gabriel
Posted: Tuesday, March 05, 2019 - 06:03 AM UTC
I'm racking my brain trying to remember exactly what those pipes were as the last time I actually saw them was back in the very late 50s.
For starters one is a fresh for air, the other is part of the heater system.
On the very left that is the fresh air intake with a manual flapper to close of the flow of so called fresh air. I still think it's pretty funny that they sucked in air from the engine compartment that had all sorts of engine fluid smells.
To the right of it is two hoses, they moved hot water from the radiator core top to the heater core. The other hose for the spent hot water being returned to the radiator to start the cycle again. The other duct is right below the actual heater fan which is behind that plate. That's where the air for the heater system comes from. I just don't remember if it was actually attached to the radiator or just hung off of a bracket near it.
Posted: Tuesday, March 05, 2019 - 06:07 PM UTC
Thanks for the feedback guys, here are a couple more reference images of the same engine bay from different angles. The trunking attaches to the front radiator brackets on either side of the radiator, so I think they take fresh air in before it hits the engine bay.
Plenty of scope for scratch on the wiring and hoses here.
Merlin
Senior Editor
#017
United Kingdom
KitMaker: 17,582 posts
Auto Modeler: 388 posts
Posted: Friday, March 08, 2019 - 09:34 AM UTC
... I am kicking myself that I didn't go over the fender skirts one more time before I hit the airbrush.
Hi Damian
That could be the sub-title to my modelling "career"!
But, in all fairness, if I could get a quid for every time I thought I had a seam looking perfect - only for a coat of paint to highlight it like the Grand Canyon!... - I'd have a nice little nest-egg to look forward to one day!
Your build is just looking great!
A classic '50s American car kit like this is definitely in my sights and causing an ominous itch in my wallet, so I can't see it being too long before I succumb!
All the best
Rowan
BEWARE OF THE FEW...
As I grow older, I regret to say that a detestable habit of thinking seems to be getting a hold of me. - H. Rider Haggard
