When you get to the business end, and try to get everything to line up and play nice, you find out how well you have actually done when you think that you are taking a lot of care! A bit of bending and twisting, half a bottle of CA (including application to my fingertips), reattaching a couple of parts a couple of times, the odd profanity, but it's done
I will look over it again tomorrow night and see if I need to touch up a couple of spots, and probably add a bit more pin wash here and there, but it's about as good as it will get before the show on Saturday.
Things I've learned in this build:
1. Look closer at the body before priming, double check those mould lines and flow lines are really gone. Double check again AFTER priming, there are a couple of faint lines that really annoy me.
2. Don't mask and paint the chrome so early in the process. I couldn't cut and polish the paint evenly so it didn't get done, and the constant handling wore off a bit of the chrome trim so I had to remask and respray the side trims.
3. Test fit over and over, and look harder for potential trouble spots. The body fitted nicely over the chassis and tub assembly, until I put the rear glass in. The thickness of the rear glass interfered with the rear parcel shelf and made it very difficult to get the bottom pan to fit up inside the body.
4. Molotow pens are great for touching up chrome parts, first time I've used one, but go
LIGHTLY, that stuff just flows out like red wine if you press too hard.
5. Make sure you put a fresh blade in the Xacto to trim masking around body mouldings. There are a couple of places where the not-so-new blade pulled the masking up very slightly, but enough to get a bleed underneath. Brush applied touch-ups are never as good as the airbrush finish.
I will get some better photos outside in natural light, and there will be a bunch of photos of the other builds at the show on Saturday.
