I started working on the driver's compartment which is comprised of various sub assemblies. The 1st one is the floor pan. Various electronic components were painted Flat Black then glued into position. I added three rubber clad electronic cables that I painted in Semi Gloss Black so that they just didn't disappear over the tops of the various Black boxes. Unfortunately, the lights just reflected way to much light back towards the camera. After seeing these pictures, maybe I should consider toning them down a tad. finally the fire extinguisher was painted bright gloss Red, and the holding straps were made from BMF. For me that's way easier said then done, but eventually I got both strips into place.
The exhausts are each just two halves that needed a little Tamiya putty to blend in the seams. I primed them Gloss Black then Alcad 2 Stainless Steel was air brushed on. The two engine compartment supports were also painted with Gloss Black followed by Alcad 2 Steel for a slightly different look.
I then built up the interior roll cage that fits like a glove. Primed then painted a Neutral Gray followed by a coat of Mr. Color clear Gloss. When dry, I hand painted all the rubber pads flat Black.
Up next is the engine compartment sub assembly. The engine and exhaust are molded into the compartment. This created the need for quite alot of masking as the compartment is neutral Gray, the back panel is Flat Black, the exhuasts are Metallic Metal, and the engine is a dull Red. So I decided to paint the engine and exhausts by hand. The engine fuel injection covers were air brushed Mr. Color Metallic 2 Silver which looks more like polished Aluminum, which is the metallic color I was looking for. When dry, the Audi decals were applied. The two intake lines were painted with Aluminum, and Nato Tamiya Rubber for the boots. The engine compartment support rails were painted exactly the same as the roll cage.
Now for the fun part. I dry fitted all the assemblies. The fit is nearly perfect, but some tweaking of the roll cage where it meets the engine compartment railing is necessary. Still it's starting to come together nicely.
And thanks for stopping by and checking out my build to date. As always, it's greatly appreciated.
