Michael M, you and I were in the same boat, trying to figure out to make believable and sturdy control arm connections. What you see above are from Prime Miniatures - very nice, small parts of all kinds. It took forever to find them as a source!!
I've tried several alts to their brass parts - making my own tiny eye bolts from wire, various mods to styrene, cutting and drilling my own from sheet and solid aluminum rods, and even brass sheet and bars. The results have ranged from good to bad, but in either case, it's not easy to make many of them that look the same.
Michael K, funny you'd say that, I've often wondered how people make the master for a vacuuform project?
OK, on to today's updates.
Minor, or maybe major victory #2. In this process, I was able to get the cab to tilt, and then swing back to where it is supposed to be seated! Maybe not a big deal for many of you, but this never works for me - be it a Tamiya, Fujimi, or MFH kit - usually very close and usually not precisely right. For the Pete, it works:
I took a lot of time to look at how the real hinges work and how they are mounted. The lower arms come from the junk box, really just a lucky find. The uppers are made using aluminum sheet - drilled out to receive a pin, then filed as needed to allow rotation, then bent to 90 degrees. Realizing how often I knock parts like these off, I drilled holes for mounting pins into the aluminum brackets and the bottom of the hood, then inserted and glued metal pins.
Along the way I began scratch building tanks and the battery box. This is mostly just styrene, but also includes various odds and ends. In addition to trying to estimate sizes etc, these parts need to be mounted "off" the chassis to allow space for the cab's air ride cushions. So, they are off-set.
I just had to try - this required a variety of subtle but important modifications to firewall to get my scratchbuilt hood to seat correctly. I also added internal bracing to hood to keep it square. This allows the engine to be seen, and invites mods to the firewall. Those of you interested will see I fixed the appearance of the u-joint on the steering column - no longer just pinned in place.
Finally, back to the fuel tank:
While not perfect, I like it!
Ok gents, stay well and happy model building
