12 Days? I've been cleaning parts for longer than that on a kit this size.
Looking great Gabriel!
VW Beetle Cabrio 1303S by Aoshima
Posted: Friday, September 11, 2020 - 11:17 PM UTC
Posted: Sunday, September 13, 2020 - 01:17 AM UTC
Michael & David - with a kit simple like this, 14 days now it is rather a counter-performance
I've been working in short bursts, as time allowed, nd the quality suffered. (see the update).
UPDATE - no luck after all
On the underside I did as much as I could with the little detail kit has to offer: some accents added:
Body masked and the luggage deck primed:
Same went for the two versions of the tops - my friend will choose which one she likes best:
The area sprayed with an off white acrylic mix (white + burnt sienna):
Same for the tops - these received a coat of clear acrylic matte as well:
Test fit with the top up:
The runner boards masked off and sprayed with MS Surfacer 1500 black for semi-gloss black:
I didn't make a mess this time and there is very little to touch with paint:
Dry-fit with the dropped top:
... and there is the bomb:
WHile masking / unmasking the body I noticed these 2K runs which I missed before
Back to sanding!
I've been working in short bursts, as time allowed, nd the quality suffered. (see the update).UPDATE - no luck after all
Back to sanding!
Posted: Tuesday, September 15, 2020 - 11:21 AM UTC
The exhaust ports and the rear bumper added to the body - also a set of decals from the kit.
The body sprayed again with 2K - maybe not as smooth as first time but as glossy. I don't think I have more to do to it than to add external details:
Posted: Tuesday, September 15, 2020 - 05:14 PM UTC
Looks spectacular Gabriel.
Posted: Tuesday, September 15, 2020 - 11:50 PM UTC
Thanks, Jesper
Posted: Wednesday, September 16, 2020 - 02:57 AM UTC
You're certainly becoming a 2K master. Nice save. The resprayed body looks super shiny.
I do like the closed top version better, but that's just me, and what does an old cook like me know anyway.
The bottom pan looks just fine with the detail paintings and light weathering.
You should be wrapping up this build in no time flat.
Posted: Wednesday, September 16, 2020 - 10:51 AM UTC
Thanks, Joel - I still think the first coat was better, if not for the unfortunate runs.
In this colour scheme - indeed - the top-up version I find it better myself.
Not much left to do - other than chroming and exterior details - but I am running 3 projects in parallel right now in real life and time is scarce.
Posted: Wednesday, September 16, 2020 - 12:19 PM UTC
I'm with the others - it looks fabulous!
Posted: Thursday, September 17, 2020 - 12:38 AM UTC
Seems that you're a man of many talents. As for time being scarce from so many real life projects, being retired is a true gift from the Gods. Other then a "Honey to do List" that never shrinks, I've got all the time in the world. Too bad that every other factor of old age conspires against truly enjoying all this new found time.
Posted: Thursday, September 17, 2020 - 01:05 PM UTC
Looks amazing Gabriel, great work! I'm undecided on the top-up or top-down question, both work really well!
A quick question, are you going to cut the decal around the bottom of the door and the door hinge and settle it in further?
Posted: Sunday, September 20, 2020 - 05:21 AM UTC
Thank you, Michael
Yes, I am in the middle of a lot of things. That's not very helpful for modelling.
Damian, That was a kit's flaw that I didn't noticed until it was too late: there is no panel line between the bottom of the door and runner board. I could have it scribed in the moment I cleaned the shell, but never crossed my mind because I just didn't see it. I will simulate it by wash.
The decal laid very good around hinge; again, a wash will do - I hope.
Chrome foil added to simulate the chrome inserts. It has a couple of errors that can be still corrected and I'm going to go one more time over them
The lights bezels and the bumpers added. Here I've tried for the first time to deal with the chrome on the bezels
The rearview mirror and the rear light plates also added:
There are some ugly gaps remaining between the light bezels and the body (left side). I covered them with tinted white glue (right side); the excess was latter removed.
The effect of the "gaskets" isn't all that bad, but my problem here was the bezels. My patch with Molotow chrome pen made the looks even worse:
Right now I took the bezels off and I'm going to Alclad them after cleaning.
Interior panels and the dashboard added. The dash goes in straightforward, but the door cards are molded flat while the body is curved. I know: the panels should be rather flat, but in this case gaps will show at the middle, top and bottom.
Posted: Sunday, September 20, 2020 - 07:46 AM UTC
Still one happy looking bug. Looking great, keep it up.
Posted: Sunday, September 20, 2020 - 08:35 AM UTC
You're slowly but surely bringing that Bug up to your standards. So far you've beat every issue back, and I'm positive that you'll continue to do so till the Bug is done and in the books.
Posted: Sunday, September 20, 2020 - 10:49 AM UTC
Thanks, David! I will!
Thank you for the vote of confidence, Joel! I don't think the bezels issue cannot be beaten ideed.
Posted: Sunday, September 20, 2020 - 11:52 AM UTC
Gabriel, you are working though a catalogue of small problems on this build, and doing a great job!
With regard to the headlights, would it be worth stripping them off to bare plastic, then gluing on a fine rod to create a "flange" to cover the gaps at the fender? Then refinish with Alclad. This might be neater and easier than trying to fill gaps around the installed bezels on that beautiful paint job.
Posted: Sunday, September 20, 2020 - 12:46 PM UTC
Thanks, D.! Your idea would have been an excellent idea if the bezels were parallel with the body, but in this case the body shape is slanted in rapport with the axis of the cylinder forming the bezel, which is also slightly conical. Yes, the protrusion limit can be traced and material added accordingly, but it would be already more complicated than just filling up the gap with glue.
Posted: Sunday, September 20, 2020 - 12:56 PM UTC
That sounds like me, an excellent idea that makes things more difficult than they already are
I'm sure you've got it under control.
