Tony,
Yep, 12 inches is probably too far away. I use mist coating for building up enamels and lacquers so they don't run, but it doesn't work well with Future because of it's self leveling properties. It's designed to be applied in heavy coats, and its fast drying. I recommend turning up the paint flow on your AB up and turning down the pressure to start. If you hang the model from a coat hanger, the Future will naturally drip off, and you can use the "wicking" method above to remove the excess, then just let it level on its own. There's a natural tendency of modelers to mess with it as its drying, because we see drips and streaks-- just ignore them and let it dry and level on its own. Once its thoroughly dry, if there are high spots, you can sand them and re-future. As to your question about clear coats-- I would give the future at least a week to dry before clear coating. I only have experience clear coating future with light coats of Testors lacquer clear gloss and Alclad Clear Kote in the round bottles (I prefer the Alclad unthinned)-- I'd be careful with anything else-- but give the Future plenty of time to harden-- lacquers are naturally caustic, and could cause problems with Future that is partially cured-- Humidity is again an issue-- Future takes longer to dry in humid climates (like RI or Washington where I live) so I recommend finding a warm dry place to let it cure. VR Russ
thank you, this is all very valuble info. i really appreciate it.
