British Columbia, Canada
KitMaker: 473 posts
Auto Modeler: 257 posts
Posted: Thursday, August 25, 2016 - 12:00 AM UTC
Front mud guard for the frame takes shape ,to match the primary drive cover:
fbook : Custom Motorcycle Modeler Page
Thank you , Steve
Removed by original poster on 08/25/16 - 19:38:33 (GMT).
KitMaker: 473 posts
Posted: Thursday, August 25, 2016 - 11:04 PM UTC
Footpegs ongoing:
Thank you , Steve
Namabiiru
Rhode Island, United States
KitMaker: 2,888 posts
Auto Modeler: 32 posts
Posted: Friday, August 26, 2016 - 04:47 AM UTC
I've been away for awhile, but I see you're still going strong. Fantastic work!
KitMaker: 473 posts
Posted: Friday, August 26, 2016 - 08:39 AM UTC
Thanks Mark, stay tuned for the grand finale , show in October.
Didn't like the footpegs so I redid them:
Thank you , Steve
KitMaker: 473 posts
Posted: Sunday, August 28, 2016 - 12:36 AM UTC
...and in for finishing:
Thank you , Steve
KitMaker: 473 posts
Posted: Sunday, August 28, 2016 - 01:50 AM UTC
Front mudscreen gets fitted:
Thank you , Steve
KitMaker: 473 posts
Posted: Sunday, August 28, 2016 - 10:45 AM UTC
Rear fender and strut get going:
And these into black:
Thank you , Steve
KitMaker: 473 posts
Posted: Sunday, August 28, 2016 - 08:38 PM UTC
Moulds cleared and some cleanup to do , but I will be moving towards pouring the metal today:
Thank you , Steve
KitMaker: 473 posts
Posted: Tuesday, August 30, 2016 - 02:44 AM UTC
All day effort results in the rims and hubs getting done. I need a break before tackling cleanup and finishing of the wheels:
One of the best reasons for this work is that the kit tires fit my cast wheels nicely:
Thank you , Steve
KitMaker: 473 posts
Posted: Tuesday, August 30, 2016 - 07:12 AM UTC
Hubs cleaning up nicely, I need these first to set wheel spacing and chain run:
Thank you , Steve
KitMaker: 473 posts
Posted: Thursday, September 01, 2016 - 02:07 AM UTC
Hubs. They aint the best , and could be improved on, but they will work on the killer hillclimber.
Cleaned up and into finish:
And some flat black primer filler from Alclad, sprayed dry to get a grainy effect , this can dry a while then cast aluminum from the same manufacturer:
Thank you , Steve
Namabiiru
Posted: Friday, September 02, 2016 - 04:43 PM UTC
Tres kewl!
KitMaker: 473 posts
Posted: Friday, September 02, 2016 - 11:26 PM UTC
Thanks Mark.
Here the hubs are sprayed with Alclad white aluminum , they retain the grainy look desired, a brushing will remove most of the grain.
On to the rims now...
Thank you , Steve
KitMaker: 473 posts
Posted: Saturday, September 03, 2016 - 09:24 PM UTC
Rims cleaned polished drilled and cleaned again then into Alclad gloss black base:
Thank you , Steve
KitMaker: 473 posts
Posted: Monday, September 05, 2016 - 10:58 AM UTC
Some parts going on. I wouldn't normally attach the tank at this point but it has numerous fuel lines emanating from it so some epoxy will hold it tight. Front fork sliders get their initial fitting. I dunno , looks pretty cool to me:
Thank you , Steve
KitMaker: 473 posts
Posted: Wednesday, September 07, 2016 - 11:19 PM UTC
Fuel lines begin:
Thank you , Steve
KitMaker: 473 posts
Posted: Thursday, September 08, 2016 - 12:23 AM UTC
And the chain assy tool gets a viewing/access slot milled:
Thank you , Steve
KitMaker: 473 posts
Posted: Thursday, September 08, 2016 - 04:06 AM UTC
Detail piling up today. Carb gets its first line, the high-speed auxiliary jet gets plumbed from the bowl. The rocker shafts get their socket heads, the top motor mount gets bolted and the tank gets its bolts and washers.
Thank you , Steve
KitMaker: 473 posts
Posted: Thursday, September 08, 2016 - 07:10 AM UTC
Nightly paint sessions will be the norm until this mother is finished. Tonight the right footpeg assy and the axles and rear fork pivot bolt get theirs:
Thank you , Steve
KitMaker: 473 posts
Posted: Friday, September 09, 2016 - 09:39 PM UTC
Clutch pack gets detailed:
Thank you , Steve
KitMaker: 473 posts
Posted: Saturday, September 10, 2016 - 02:44 AM UTC
Fuel feed and return lines get attached:
Thank you , Steve
KitMaker: 92 posts
Auto Modeler: 57 posts
Posted: Saturday, September 10, 2016 - 02:49 AM UTC
Dude, your are setting the standard! Amazing master class build!
We come in peace, so shoot to kill...
KitMaker: 473 posts
Posted: Saturday, September 10, 2016 - 06:59 AM UTC
Thanks Snowman.
Test fitted so many parts so many times , still testing and everything , so far , has fallen into place:
Thank you , Steve
KitMaker: 473 posts
Posted: Friday, September 16, 2016 - 11:13 PM UTC
Handlebar work to start the weekend sessions , clutch cable , kill wire , and throttle cable attachment:
Thank you , Steve
