UPDATE - where are them lines going? (Caribbean "English")First off, I had yesterday a lengthy conversation with
Luigi, the owner of the
Chrysler about some details. We disagreed about the color on the outside of the bottom pan. I wanted it body color, he wants it semi-gloss black. I pleaded that black of the chassis frame on black of the bottom pan will absorb all detailing - he still wants it black. Eventually he conceded that I should do the chassis gloss black and the bottom pan semi-gloss black.
Another discussion was centered around the brake lines. I wanted to make them, he says it doesn't matter, they're not going to be seen anyhow. Then I observed on the differential axles that the brake lines are actually molded there (quite soft, but they are present). That tipped the balance in my favor, but actually put me in trouble because I don't know how they suppose to reach from the brake booster to the differential cassette. Can anyone please help with the issue, based on the following photos? Thanks!
The chassis is very nicely done, although (again!) were some trouble with fitting the tie rod. I dare say the detailing on suspension / direction / transmission it is above
Tamiya - at least for the kits I was working on myself:
The shape of the tie rod isn't all that good, being more shallower than needed to bypass the torsion bars. The result is an increased length, that pushes the wheel axles in a cross-eyed position. The solution was to glue one end in place, wait for it to dry, then forced it to the correct bend and glue the other end as well:
The rear end suspension / transmission is rather simple and all went smooth, except for a locator pin that was off the mark, twisting the right side lamellar spring around its longitudinal axle. Fixed it by melting the troublesome pin with
Testors glue and forcing it to the right angle:
I could have gone ahead and painted the chassis, but I wanted to glue first the clamps for brake lines, which I don't know where they go
I used the little time left to paint the white inserts of the tires with gloss
Rust-oleum almond to make them more antique. Here you can see them in comparison with the original sprue white:
In this picture you can see them next to a spoon painted on body color - and I think they look much better than they have looked in "pure white":
The chrome parts have to be re-chromed because the exposed plastic from the cuts can be seen. Ialso I have noticed some scratches on the front fender. I will polish the problematic areas, then I will spray
Alclad II chrome right over; I'm still thinking if I should apply a coat of polyurethane or 2K after Alclad, but I'm more tempted by the polyurethane because its yellowish tinge. Any suggestions?
I will really appreciate if anyone could help me with the line brakes!
Thanks for following!
