Carrying on with the clear part surgery, I marked and cut the side sections off to just leave the rear glass, with plenty of "meat" on the sides still to get a good surface to glue.
Once I had the glass cut, I decided to get back to the interior and get it finished off. The gear shift was still annoying me, so I got a pair of sprue cutters and snipped it off at the base. Now, what better to use to replicate a black rubber boot, than black rubber
Well, worth a try, but a fail on this one! This was the tree from a set of rubber tyres, but even with a new blade I couldn't get it to carve neatly. It just kept bending and twisting and after a couple of attempts it was in the bin.
Next option, black sprue.
A combination of a ceramic scraper to get rid of the flash, a pencil sharpener to give it a taper, a round needle file to carve a profile in it, and a quick swipe with a sanding stick to tidy it up, and here we are.
I also used the ceramic scraper to remove the chrome from the gear shift shaft and whittle it down a bit.
A few twists with a little drill bit in the pin vise and time to test fit.
All good, apply TET and wait a few minutes, then razor saw at the desired height, and we have a much more interesting looking shifter.
Finished a bit of chrome detail painting on the control knobs and CA'd the dashboard in place, fitted off the steering column and wheel, and last but not least, the gear shift assembly.
Much happier with this now, interior complete!
Engine up next.
