As promised, I blew the cobwebs out of the airbrush gear today and found out whether I remembered how to do this!
First up the El Camino. Not much to show here as a lot of the engine components are plated, and the exhaust is moulded to the floor pan. This will be masked and sprayed along with the fuel tank.
Then the Convertible. Much nicer moulds and detail than the AMT kit, and separate exhaust systems will look much better. Once again the fuel tank will be masked and sprayed.
The black is Tamiya acrylic XF-1 Flat Black, the Orange is Tamiya acrylic Orange X-6 with a couple of drops of Red X-7 to tone it down. Both thinned about 50:50 with MLT. The NMF is Alclad Airframe Aluminium directly onto the kit plastic which was a glossy metallic black. Turned out pretty good to my eye.
I use an old Sparmax direct drive compressor (no tank) and have just started using my first double-action airbrush, a Hseng HS-80. I spray at 12-15PSI. In the past I have used a Paasche-H single action which I still have and will keep using for broad area work.
Hopefully a couple more hours tomorrow will see some engine assembly on both kits.
