Most of the parts are on the frame and it's been painted metallic black. There are a couple parts on it that'll need detail painting and some I've painted but not yet installed. There are 6 parts that are attached to the brake backing plates, but I'm not sure exactly HOW they go on...until I put the hubs on. The front axle was mounted prior to paint. I made sure the rear axle assembly was level and true then used 6 Tamiya bottles to support the axles and level them before I glued the rear assembly on. Nice and level.
The interior will be done in Medium Gray with WWI blue aircraft highlights (curtain and sheet as you can see). Center of the seats and perhaps the door panels will also be done in the blue.
I've been trying to figure out the cab exterior color, tanks, battery boxes, etc. I picked up a Light Gray Metallic and gave that a shot (pun intended). The fuel tank is that color. I think it's too light...seems more of a silver. So, I'll probably skip that color and check out a Light Gun Metal, IJN Gray, or maybe Dark Ghost Gray. The tanker trailer that'll be hooked up to this will be in a matching paint scheme, so I have to choose for both kits.
Pretty much all other colors are per the instructions.
Thoughts?
