Richard, so sorry for your loss.
A textual update from me on the Bronco. I again have been on the road for the last two weeks, only home on the weekends so not a lot of time at the bench. This and the next week are travel as well, I'm currently in Duluth, Minnesota.
Body shell, interior and most all other parts were primed. Chassis, roll cage and suspension units are built and painted MM SG Black, Engine is mostly done except for the starter motor, oil pan and belt drive assy. Paint on it is a custom Ford Blue shade made from 60% MM Grabber Blue and 40% MM Ford and GM Engine Blue, really like how it came out.
The late model 5.0L upper and lower plenum from the Revell 5 Window Coupe fit almost perfectly in the valley with only a couple swipes of a file needed. The valve covers from the same kit needed the tops of the Bronco's heads shaved of the alignment ribs for the kit covers.
Had a small issue drilling out the distributor cap and ended up ordering and installing an AM one I got from Ted's Modeling Marketplace. Of course, the firing order is correct for a late model 5.0L and not the original 302 firing order. (The change to the 351 Windsor firing order smoothed out the idle helped torque through added scavenging.)
I salvaged an MSD box from an old NASCAR dashboard with some filing so I won't be using a coil.
The interior will have a lot of the main body color to be painted still as does under the hood (bonnet to the rest of you). Seats and the door cards (door panels to us in North America) received a custom light ivory color blended from 30 drops MM Classic White with 4 drops of MM Gulf War Sand. The grill was hit with the same color.
On to the bad, I was mocking up the interior and added it into the shell, only to find that on the right side I removed material for the flare cutouts at the wrong angle and have exposed some of the wheel well side. Going to have to work on a fix for that prior to laying down color.
Due to the amount of travel I'm doing (including a possible trip to Japan in March), I've decided to scale back on the scratch building I was planning. The tire carrier, rock sliders, etc. are not going to happen on this build. I'm just hoping I'll have something to present by the end of March.
