I'm leaning toward the AMT 1966 Ford Mustang.
Damn, another Ford. My plan for Chevy world domination just took another backward step!
Damn, another Ford. My plan for Chevy world domination just took another backward step!![]()
seriously looks great decals,paint,details.
Very nicely done.
From what I've read on the Testors Metallizer's they're a very mild lacquer based paint, so they generally won't crazy plastic, but your mileage may vary. Using Tamiya Gloss clear works as it's the same base. Personally, I would have let it cure for a full day just to be on the safe side. Clear coating will dull the finish a tad. But for the look you're after, it's perfect.
As posted in the T2 build thread:
Been doing a lot of small detail painting and such on the suspension and dashboard. Not really much to report. A long way to go still, and slow progress happening. Not to happy with the way my brush painting on the dash and upper door trim came out.
Plan for this week is to mask off the interior and shoot the body color on the underside and engine compartment. If the body shell primer looks good when I pull it out from under the plastic tub I have had over for the past couple weeks I'll shoot it at the same time.
I'm sure that your air brushing will turn out just fine.
That really does suck big time.
I'm a major player when it comes to use Gravity Paints. But like with all lacquers, I follow my protocols. When you say all four sides are crazed, do you mean the primer or is the plastic actually crazed? If it's the plastic, it's a lot harder to deal with, but it can be done.
Bill. That paint looks really good, nice an smooth. Patrick. Well done the wings look like aluminium as they should.
