all sorts of big progress here! nice -I'm moving along with the IMSA Mustang. The base kit is pretty nice and includes a fair amount of detail as is. The chassis/body/layout is odd - the front is stretched way forward of the engine and axle, and the rear of the chassis rakes upward as it gets closer to the very end of body. All of this tempted me into adding some detail work. I looked the car up on line and found all sorts of interesting attributes - ranging from four link rear end to the unusual engine bay, and metal rocker panel above the exhaust on the driver's side. Please take a look:
I started with the above so that you can get a sense of the complexity of this car - not what I thought when I started. Next, some suspension:
Despite all the room up front, radiators and screens are in the rear wheel wells (and yes, the real life screen is also set in metal rod cages) - this was some interesting scratch work!
Also, you can see, by opening up the rear deck, you are able to see the back of the roll cage - so, I added it (and the fuel cell) too -
Finally, the engine is pretty interesting too, with the turbo and coolers. If you look carefully you can see the various bits of hardware etc that I've added:
You can also just barely see the work "Ford" on the head -
Ok, keep going GB!
