That came out absolutely phenomenal Gabriel!
Thank you,
David! You are just too kind. It was a good build, but it has "glitches".
Beautiful finish Gabriel, another gem in the display cabinet!
Thank you,
D.! Actually a collections of NASCARS will make a very colorful display, you're right. As you all know, I'm not a collector, I'm a builder so off they go in Canada!
The Hot Wheels/Kyle Petty car just came out looking fantastic. You out did yourself for sure on this build.
Thank you so Much,
Joel! In all frankness, I didn't feel I pushed myself in this build, I just took a little more time and took the time to redo the small mistakes I did along the way.
Damian Nice preliminary works. Finally that engine looks like an engine and not like a drying piece of Dutch Cheese
Now, on the bumpers, I've seen you primed them with black but the finish it's satin. The chrome it's going to be also satiny - I just tried on my
Pontiac's
Chevrolet engine. If I'd be you, I'll prime everything gray, mask the bumpers, gloss black them, and only then I'd apply chrome. Of course, all depends on what effect you're after. Also, masking over bare metallic finishes might result in damage, as the tape will pull away metallic pigment, making the finish to appear dull. Just a thought. One more argument: if you want to get the best out from your metallic paints, they should be applied over the black base while the base still wet, resulting in much nicer self-leveling. The method it's also confirmed by
Joel's experience.
