#335
Auckland, New Zealand
KitMaker: 1,808 posts
Auto Modeler: 701 posts
Posted: Sunday, June 21, 2020 - 12:37 PM UTC
Looking real good Sir. I'm more then impressed. Are those two "storage tanks" for gas? If so, the weight distribution must have been a major issue as they went through a load of fuel.
Hi Joel, not for gas, for luggage. You didn't have put anything in them, they just had to be there. Rules for different classes of Le Mans cars were odd at the best of times. The 908 did not require the spare tyre, luggage space or extra seat that the 917s did. Some classes today still require these, like the LM GTE cars.
Campaign:
Strip, Track and Trail - Porsche 917/20 - On the bench
Phantoms at 60 - F-4J Marines
Below 1000 tons - M50 minesweeper - Sailed for duty
#335
Posted: Sunday, June 21, 2020 - 12:39 PM UTC
Time for a little update on my '55 Pro Sportsman. I've been struggling with the tube frames around the engine bay. They fit very tightly around the headers, and if I have glued the headers on slightly out of position the tube frames press against them and won't sit neatly in position. I am playing around with them and doing some "In Field Styling Modifications" and they are almost there.
Sounds like my issues. Good luck with those
Campaign:
Posted: Monday, June 22, 2020 - 12:35 AM UTC
Thanks for the info. I always hated the spare tire and pass seat rules. Once they figured out how to make miniature tires, it really became a joke, and those pass seats got smaller and smaller.
Posted: Tuesday, June 23, 2020 - 06:11 AM UTC
I love the smell of Tenax in the morning....It smells like a day off work.
I drive a Jeep, but i still bleed Ford Blue....
Posted: Tuesday, June 23, 2020 - 07:39 AM UTC
Wow
Absolutely love the color. You nailed it for sure.
Posted: Tuesday, June 23, 2020 - 08:43 AM UTC
Thanks Joel, hope I can do the decals justice.
Posted: Tuesday, June 23, 2020 - 09:17 AM UTC
I'm betting on it. if you can paint that good, decals should be a breeze.
Posted: Tuesday, June 23, 2020 - 04:45 PM UTC
Looks amazing David, great work!
Posted: Wednesday, June 24, 2020 - 12:19 AM UTC
Thanks D.
Hope to start decals soon. The next two nights are tied up with conference calls to our Aus. offices and then our Japan dealer.
This work stuff is getting in the way...
Posted: Wednesday, June 24, 2020 - 05:01 AM UTC
David, that looks really cool! Hope you have great success with the decals! I know you will!
Just completed-
1/24th Tamiya Porsche 956 Skoal Bandit
In the works:
1/12th Protar Ferrari 312T2 (shelved for time being)
ERTL D-8 Caterpillar Bulldozer
Posted: Wednesday, June 24, 2020 - 06:19 AM UTC
Thanks Patrick.
Did a test decal a couple minutes ago.
The decal company supplied silver blanks to go under the decals. I figured that is because they think the white isn't opaque enough to stop bleed through. Well, I tried a sacrificial one in an area that will be less seen without putting the silver backer down, it also had the distinction of being the only decal that really needs to settle over details.
The white is strong enough, and it settled quite well, but they are grabby and thin. Water, Set and Sol only on these.
My 8 PM conference call for this evening got pushed to next week so I may be able to lay a few down tonight.
Posted: Wednesday, June 24, 2020 - 07:46 AM UTC
Interesting that they gave you silver backer decals. I would have thought that they would have used just plain white. Still, it's a really nice touch.
Posted: Wednesday, June 24, 2020 - 11:53 AM UTC
Joel, I thought the silver was weird too. They have it on a lot of their sheets that use a darker color paint. One other weird thing is that their D&W on black scheme for this car doesn't have the silver.
Anyway, they are very slow going due to the thinness of them. Several of them curled under the backing paper as I was trying to slide them onto the body. I started with smaller ones and managed to get nine done in one hour this evening. Only 30 or so more to go.
#335
Posted: Wednesday, June 24, 2020 - 12:08 PM UTC
Looking good David. The colour certainly looks like Jägermeister Orange. Looking forward to see the decals go down.
Campaign:
Posted: Thursday, June 25, 2020 - 01:42 AM UTC
If you're having issues with decals sticking ASAP to the plastic even with Micro Set, I go to Plan B, which is a little room temp water with a drop of liquid dishwashing detergent like Dawn. the Decals just slide right where you want them. Then a wick around the decal to start to settle it in followed by a lite pat. then comes the Micro Set followed by the Sol. The less you have to pressure move thin decals, the better you are.
Posted: Thursday, June 25, 2020 - 03:45 AM UTC
Thanks Michael, and also thanks for the umlauts too. I didn't feel like going into ASCII code to get them. Jägermeister LOL
Joel, they are only slightly clingy. I started to flood the area with wet water (your soap and water mix) after the first one that I tried as a test.
Mostly the issue is with trying to wrap under the backing paper, especially with smaller decals.
I've got a system that seems to be working pretty well for them now. Between calls today I was able to get a few more on.
I am getting a slight bleed on one or two of the Jägermeister lettering. Maybe the white isn't as consistent as it should be and the decal mfgr was right. Oh well, C'est le guerre. Too late now.
Posted: Thursday, June 25, 2020 - 08:21 PM UTC
Battling through the tube frame at the noisy end of my '55 Pro Sports. Radiator, coil springs and accumulator have been added since last update as well. I'm about 75% there on the engine bay area with a couple of straight braces to add then brake discs and tidy up the paint.
Posted: Thursday, June 25, 2020 - 11:41 PM UTC
Looking great D. The bay bars, engine and equipment look real nice together.
Posted: Friday, June 26, 2020 - 12:53 AM UTC
Your making excellent progress for sure.
Posted: Friday, June 26, 2020 - 05:33 AM UTC
This week I've concentrated on the chassis, and what is modeled of the front & rear suspensions. Basically, both ends of the suspension are basic at best as the only way to see them is by looking at the bottom of the pan.
I air brushed the pan a darkish Gray to simulate Carbon Fiber. And since it's never going to be seen once it's in its display bin, it's more then good enough for the intended purpose. For me the focus is on the 4 disc brakes as you will clearly see them through the wheels. The discs are steel, the hubs Aluminum, and the Calibers Titanium Aluminum followed by the makers logo. I gave each disc a wash with Tamiya Black panel line wash just to help pop out the view details. I also painted the transaxle aluminum but once the interior is added, you'll never see it.
the Front brakes:
The Rear brakes:
the radiator and fan housing will be visible when looking down through the radiator exhaust opening in the hood, so it was air brushed with Dark Gray to simulate CF, then dry brushed with a light Sky Gray.
The radiator assembly was air brushed polished Aluminum, and once dry the radiator core was given a few washes of Tamiya Black panel line wash.
As always, thanks for stopping by, and checking out my progress to date.
Posted: Friday, June 26, 2020 - 06:30 AM UTC
Looking great Joel. Nice work on the brakes. Good color differentiation between the components and the wash makes it even better.
Posted: Friday, June 26, 2020 - 06:37 AM UTC
Posted: Friday, June 26, 2020 - 07:58 AM UTC
Thanks for the thumbs up, it's greatly appreciated.
You decaling looks dead on perfect to me. I'd settle for it any day of the week.
Posted: Friday, June 26, 2020 - 08:54 AM UTC
Thanks Joel, I appreciate it.
The one that stands out to me is the waviness of the one on the left door. Didn't even see it until the picture was on the computer.
Posted: Friday, June 26, 2020 - 11:13 AM UTC
Wonderful work everyone! I am not getting much done these days as we are acclimating my wife back to work after 15 months of repair on her chassis (bilateral hip replacements), family springing in, and a planned visit by my son from Little Rock the first week of July.
I will try to get a little done this Sunday but it won't be much. Working in 1/24th scale is a bit more frustrating especially since this Porsche has THREE different colors on the pan... white, chrome, and semi-gloss black. And then there is the cockpit...
Anyway, it is a slow go... and I almost gave up and went back to 1/12th scale. But I will not be defeated as I spent $47 on decals! LOL!
Just completed-
In the works:
